I had a similar problem about 18 months ago on my Honda. It was an incredibly awful whining noise. Apparently, a small, but hard, piece of wood (about 1/2" long) was picked up on the freeway, while I was going about 65 miles per hour, and lodged itself between the brake disc and the splash guard on the front right wheel. It stayed there for several days and drove me nuts. When I turned the wheel and backed up the noise changed from a whine to a screatch.
Jack the car up on an appropriate lift. Start the car, put it in reverse, and rotate the wheel to the right. If something is lodged, you will hear it. After the hub was removed, a piece of stiff wire was used to dislodge the item.
If the above does not sound like your situation, you might find out the specs for "seating" the wheel bearing with a torque wrench and how much it needs to be backed off afterwards, if any. It might be that you tightened it too much. Overtightened bearings can fail in a hurry. Wheel bearings can handle load but they are not good at withstanding lateral forces. Another possibility is to check the condition of your CV joints. The passenger side normally goes first. They aren't that big a deal to repack yourself.
