how do I get the door panel off to get to the front speakers
I have a 1996 taurus gl
helpppppppppppppppppppppppp please
thanks
thanks
thanks pimpingOriginally posted by Twilight@Mar 17 2004, 09:28 PM
The screws are:
- A couple (2 i think) on the side of the panel
- A couple (2 also i think) on the underside
- 1 in where the handle is.
Remove those screws then pry from the bottom around with a screwdriver (flathead of course, preferably a large one you can pry with).
The stock plastic clips can usually be re-used once if you're gentle when you pull them out. You will need to lift the door panel up over the lock to get it off. You can access the speakers without pulling out the harnesses.
