I did a few things; new ball joints, inner tie rods and ends and sway link bars. Seems to drive good, but if I turn right or left not even into a full u-turn it just pulls itself into a uturn and does not straighten back out without me turning the wheel. It does fine around regular turns. Any suggestions?
+1 for alignment. Toe out of adjustment will do the very thing you describe. Did you loosen the top of the strut to help with the ball joint process? Caster/camber could be off as well. Caster is what makes it straighten itself out when you let go of the wheel.
Alignment was it. Did my own quick one using some string until I can bring it in. Problem fixed. Thanks a lot.
