1 - 10 of 10 Posts
So last summer I replaced the ball joints, tie rods, and stabilizer bars. I got an alignment and got my wheels balanced. I still have some front end vibration on this car. I can feel the vibration in the gas pedal when driving on the highway and also feel it in the steering wheel. Anything you guys can thing of / know of on these cars?
yes, summer of 2009. the vibration was there prior to the work. It was worse then - clicking/clunking added from bad strut bar linkage and a severely damaged ball joint. I replaced all these and got my tires balanced at two different places on two different occasions (thinking one place screwed it up...) and the vibration is still there. Its not really bad, but noticeable. I suppose i should rotate my rear wheels to the front to completely eliminate that possibility???? but i'm pretty sure its not the wheels.
Would bad engine mounts cause vibration like this?
As you're driving? Not likely. Good idea to rotate the tires, you might have rolled a belt or done some other damage to one of them. moving them will definitely help eliminate that possibility.
Does it buzz the steering wheel or pedal or rear view mirror? What kind of vibe? Low pitch or buzz? Does it change with speed, how fast? Does it change when you go around a bend?
Not saying I have any answers for you, but if you give better clues maybe someone else will come up with something.
I'm really bad at describing this type of stuff, but here it goes. I can feel the vibration in the steering wheel and the gas pedal. Rearview is ok. I'm not sure what kind of vibration it is, its just vibrates - feels like an unbalanced wheel(s) on the steering wheel. I only really notice it when i'm on the highway and it does seem to change with speed and it changes when going around a bend. To elaborate, once in a while i dont feel it when the car is going perfectly straight, but then when i have to hold the wheel back (uneven surface for example and the car is pulling) or when i'm going into a wide turn in the highway it will be much more apparent.
Thanks
+1 on rotating the tires. All tires and wheels have a high/low spot. When you mount a tire, you want to match the high spot on the tire with the low spot on the rim, or else you can get a high speed vibration. Other things that can cause vibration would be a bad tire belt, loose ball joint, loose tie rod end, or in my case, warped/worn out rotors (replacing mine soon).
1 - 10 of 10 Posts
