Got a problem with my wifes 02 Taurus front door locks. With the remote or using the lock button the front doors will not lock/unlock. You can see the movement in the manual lock s but they do not go lift/lower. Is there something with the actuator that lifts/lowers the manual lock that is just worn out? Has anyone had this problem before? Thanks in advance.
Lock motors might be weak or the grease might be drying up. Pop the door panels off and inspect the lock mechanisms.
Did the locks get figured out/repaired? My B-I-L's right front lock on his '01 does the same thing... (makes a noise but only twitches).
