My vulcan will go out past 5k. If I had to guess (not sure how accurate the tach is) but I'd say mine goes out to about 5300.
its not that i just must have higher reving, i want the shift points to be higher. The stock shift points put the next gear in a terrible spot, and it really bogs down. Plus i want my rev limiter raised b/c sometimes my trans will try to shift at a higher point that my engine will rev to, resulting in bouncing off of the rev limiter, and seriously slowing me down.Originally posted by Mikeys_Taurus@Apr 3 2004, 11:09 AM
What's the point? Why do you want your car to rev that high? Higher reving doesn't mean more power, just more wear.
The initial poster does have a point though. I never really thought of that. I guess it's technically not false advertising. *shrugs*
Understood.Originally posted by Taurussetypes@Apr 3 2004, 03:10 PM
That's not possible. What's really happening is your transmission is slipping.Plus i want my rev limiter raised b/c sometimes my trans will try to shift at a higher point that my engine will rev to, resulting in bouncing off of the rev limiter, and seriously slowing me down.[/b]
Don't you know that engine revs up and then transmission shifts up? I mean it doesn't shift up immediately after you press accel.Originally posted by Taurussetypes+Apr 3 2004, 03:10 PM-->QUOTE (Taurussetypes @ Apr 3 2004, 03:10 PM)<!--QuoteBegin-Mikeys_Taurusits not that i just must have higher reving, i want the shift points to be higher. The stock shift points put the next gear in a terrible spot, and it really bogs down. Plus i want my rev limiter raised b/c sometimes my trans will try to shift at a higher point that my engine will rev to, resulting in bouncing off of the rev limiter, and seriously slowing me down. [/b]@Apr 3 2004, 11:09 AM
