Here's what I used, if you're into professional grade stuff.
Hella Micro DE Fog Light Kit
The Micro DE Fog Lamp is the smallest DE auxiliary fog lamp from Hella. It provides surprising flexibility in terms of light placement and gives automobile designers, tuners and do-it-yourselfers a small trend setting auxiliary fog lamp ideal to pedestal mount in the grill, under the bumper, or flush-mount through the front air dam/spoiler.
The Hella Micro DE auxiliary fog lamp uses a halogen bulb mounted in an extremely small, sturdy and temperature resistant magnesium housing featuring DE projector lens optics. The Micro DE auxiliary fog lamp shines a white light in a wide, low, flat beam that has a sharp cutoff to reduce light reflecting off the water vapor back into the driver’s eyes. Additionally, because the Micro DE fog light beam is white in its color, it can also be used to help illuminate the road during rain, as well as, around corners and tight bends on clear nights.
Hella auxiliary Micro DE Fog Light kit #74527 includes:
Two lamps (2-5/8" H x 2-7/8" W x 5-1/2" D) with black decoration rings, H3 Halogen bulbs, soft rubber caps, brackets, wiring harness, relays and switch, easy-to-follow instructions.
Lighting, 1-FEB-2009:
Hella Micro DE Fog Lamp kit + PIAA Xtreme White Plus H3 bulbs. I would recommend this up grade since most of us have a 2-headlamp system. Adding these lamps makes huge difference driving at night (like night and day). I would recommend the PIAA bulbs over the stock Hella halogen bulbs with the kit. If you set these lamps up correctly you can use your high beams while the fog lamp is on, good to be much safer at night.
You'll have to go to either Lowes or Home Depot to buy 2" by 1/8" flat aluminum metal to create your own mounting brackets (2).
Monsoon
