I have a Ford Taurus with a intermittent issue where the RPM will flutter around 1300RPM when driving. Sometimes there is shuttering and sluggish responses when accelerating from a stop. The car seems like it is reluctant to change gears when accelerating when already moving. Accelerating from 35-40 seems to be the worst, it shutters, flutters and doesn't want to change gears. I had a another ford with a similar issue, it was fixed when the fuel pressure regulator was replaced. This seems like it is the transmission causing this issue, but I think it might be a sensor since the problem sometimes does not occur.
Here is a video of the fluttering I capture tonight. The problem seems to be subsided in this video, and no where near as worse as it has been in the past. Notice the slight flutter during acceleration at the beginning and toward the end of the video.
I had a flutter issue like that and saw improvement changing the purge valve. It could also be your throttle body. Both are easy changes.
