First about the car
2001 mercury sable Duratec engine 130000miles.
Bought this car in 2006 from the original owner with 51000miles on the clock.
The owner provided all maintenance records,the car had been serviced in the dealership only.After buying it I continued to use motorcraft 5W20 until about 85000 miles changing the oil every 5000m.After that I switched to Mobil1 Synthetic 5W30 increasing the oil change interval to 8000m.
At about 95000 replaced leaking oil pan gasket and found a lot of sludge(heavy dark oil) on the bottom of the oil pan took me a while to clean it.
Now about the issue at about 120 000 my wife complained that she gets flickering oil light at hot idle after driving about 20-25 minutes on the interstate.Drove the car couldn't see the light.Changed the oil and the filter -no more complains for the next 3000 before my wife said it is doing it again.Changed the oil again and it was OK for few thousand miles and was told that is doing it again.Finlay i decided to drop the oil pan again and check the oil pump screen.The oil pan was this time very clean the oil pump pick up screen didn't look to bad either except for a few hard pieces of RTV from my previous oil pan gasket change.Took the front valve cover and found out terrible sludge build up -something like 1/4 inch thick sludge covering everything!!! I couldn't believe how that was possible with the regular oil changes.I cleaned the valve cover and reinstalled it.I was hoping that the RTV pieces on the oil pick up screen were the problem.Put new oil and filter and it was OK for about 1500 miles before i was told again that the oil light is flickering again at hot idle.Change the oil again this time I put dino 5w30 drove the car on interstate for about 20 minutes after that did some city driving and at first traffic light the oil light came on, this time it was solid not flickering. Next day did some test city only driving for about 15 minutes the light never came on.
Decided to check the actual oil pressure connected mechanical gauge and found out that the pressure is fluctuating very rapidly 10-15psi.For example at hot idle it fluctuates between 10 and 20 psi and at 1500 rpm 30-45psi.It fluctuates so fast.The spec. for gen4 duratec is minimum 11psi at 1500 rpm .
I don't think that the oil switch is bad.Probably after interstate driving the pressure drops and fluctuates between 5 and 15 psi or something similar.
My questions are what can cause that rapid fluctuation in oil pressure-rod bearings ,oil pump or sludge.
