Just bought a 2005 wagon that was leaking at the cabin filter, followed the tsb for the 2001 to 2003, but didn't buy the rain hat. cleaned out the expanded foam and used latex chaulking as that was what i had, hose test seems to show that the problem is solved so far,
Pull back the carpeting on the passenger side footwell area, and see if the
carpeting/insulation is wet.
On my 04 wagon that ac drain was allowing water to come back in under the carpeting/insulation on the passenger side.
After hooking up a fan running it overnight the carpeting/insulation was dried out.
I sealed the area around the ac drain on the firewall with some plastic wet surface roof cement I had available in my garage.
cabin filter
My friend has also encountered the same problem with the acc cabin filter. It was also leaking and he let a mechanic check it. Well, the mechanic replace it with a surplus cabin filter from a near junkyard and till then, it hadn't leaked again.
