92 taurus L, 3liter v6.
Rad fluid is mostly water with a lil stop leak left in it right now so I want to drain all that **** out and fill it back up with 50/50, but I have a few questions first.
1. Where is the drain plug located on the rad and what direction to unscrew the plug....clockwise or counter clockwise?
2. Should I replace the thermostat as well?
3. Anything I should know before I get to work on the car tomorrow?
I know it's a fairly simple procedure, but it's my first time doing this so I would rather look like an idiot to people here and get the job done properly then look like an idiot under my car;)
Drain plug is on rad. bottom, dr. side. You have to remove blk. plastic splash guard (air dam) to access it. 19mm or 3/4in. socket or wrench will loosen it counterclockwise. Tighten hand-tight only as it is wht. plastic and will break off if you are overzealous with a wrench then you will be using an allen wrench to open and close it. A lot of people on here disconnect lower rad. hose @ the junction on the pass. side. Thermostat is your call? Also, if you have had stop-leak in the system, after draining and flushing with some h2o might consider some chem. clnr. or flush to tidy things up. Good luck. Just noticed you have a 92, so you may have a metal petcock? Also might search for the clinton heater flush.
The above is all good advice. I make it a personal policy to replace the thermostat whenever I have to open and drain a cooling system. Thermostats are a low price part and well worth the peace of mind.
