Yes I have searched, I can't find the topic with the pics of the hole, i know it's around here somewhere, can you help me?
Right now I'm using a hole I drilled myself, only later did I learn about the hole, now the time has cme that I need a bigger wire going through there and I'd prefer not to keep drilling holes.
thank you
You dont need to drill any holes. There is a hole just around and behind the brake fluid reservoir. Theres a rubber stopper covering the hole. Just pop out the stopper with a screwdriver or something. you can fit a wire up in there with no problem. I have a 4 gauge amp wire up in there, with no problems. I could probably fit another one up in there as well.
-DC
into the wheel well then through that grommet you see on the right, it then dropped down in the cabin to the left of the brake pedal.
