1 - 20 of 21 Posts
Back in June,I bought a red '97 Taurus GL. The car has been sitting for a while and it was quite obvious that the interior and exterior needed some work. After several car washes and rug shampooing, I got the car into a much better state. It still however isn't perfect. My biggest issue is this weird film on the windshield glass and the front and passenger side glass. I've tried Windex,vinger, and Invisible glass with my microfibre cloth to no avail.The film disappears when you apply water to the glass but reappears shortly thereafter.The film is not on the exterior of the glass but rather the interior which makes it really hard to reach it because its so close to the dash. This film is the worst when it is sunny out .Any solutions or suggestions would be greatly appreciated.
Kinda hard to see but that stuff on the left side of the picture is the film. It is not so bad in the picture but in sunlight it is blinding.
More pics
May need to use a straight vinegar solution to get it off, or using an alcohol solution to clean it, then regular window cleaner.
I don't think it is a tint because the previous owner was a old women who didn't do any sort of personalizing to the car. I am going to try vinegar straight up and see if that works .
Try that. Ford tints the windows a little from the factory on most cars, but I don't know if it's on the inside or outside.
Vinegar and alcohol didn't work and the film or whatever it is on the inside . I stepped it up to glass-top cleaner for stoves and nadda. This stuff is on there good. Just Out of curiosity how much would a new windshield run me ?
TCCA Facebook Admin
My dad's Crown Victoria and '93 Ram D-250 cost him $220 each without discounts, so yours should be around the same price.
Windshields can be less than that too. I would expect around $200 though.
Front window glass can be replaced easily. Just get it from a self service junkyard. Or plenty of members here should be able to get you one. Kinda a scary thing to ship though lol.
FIRST:
I would try very high concentration of rubbing alcohol. Like 92% Isopropyl Alcohol. Can get it at Walmart. You may also try an abrasive cleaner like spic n' span. Careful not to get it on the paint though because that is a good way to deteriorate it. Just use a kitchen sponge.
I think I may have found a way to remove but I am not 100% sure . I use a sonic scrub brush and some ceramic stove top cleaner to scrub away at one section of the windshield . It appears to be gone but I cant tell until I get my Halogen work light bulb replaced
I hesitate to suggest this so be careful with it inside the car. I have used pure virgin lacquer thinner to clean both glass and plexiglass and it will take off just about anything. After you get the film off then clean the residue with windex. Also don't try to do this with paper towels buy a pack of those white wash cloths that Walmart sells for a couple of bucks and as the towel loads up toss it and get another one otherwise you will just be smearing the mess around.
Apply the thinner to the cloth in small amounts and keep the can outside the car.
I have used it to take off all kind of crap off glass just be careful and have lots of ventilation no sparks or cigarettes and cover anything you don't want to ruin if you spill it.
An abrasive cleaner like I said! Let us know!
This: Bon Ami :: Products :: Powder Cleanser
might help the OP, if he or she is still around, or anyone else for that matter.
My one car previous to the Taurus was an Accord Coupe. I don't know if it was the shape of the windshield or the body or what, but that windshield was constantly coated in crap. I tried Rain X and numerous other spray on products. Nothing worked until I used Bon Ami powder.
Could also try lighter fluid...might sound strange but it's great for removing adhesive (I've used it after peeling stickers off windows) not sure what's on the window but it's cheap enough to try
I'm wondering if the film is from a slight coolant leak from your heater core. Does it smell of antifreeze at all? Try Mothers brand window cleaner. It cleaned up the film on my 73 Ford Maverick and then I used a can of stop leak to get this to stop happening.
If you believe this is a film from the antifreeze then you need to go down the road at looking at what the problem is. In my 73 I used a can of Prestone stop leak in the rad and it took care of the issue. The film came back about 4 more times and I cleaned if off with Mothers. Finally it stopped. Can't guarantee Stop Leak won't cause other issues. Anyone out there with some experience with Stop Leak in Taurus's. Good luck.
Spock
First, try a mild abrasive like Soft Scrub. If that doesn't cut it, try something like Comet.
Does you insurance include free glass replacement? Many do.
Could it be one of those Rain-Ex type polymers that are advertised to break the surface tension of water beads and make rainy weather easier to see in? If so they are supposed to be applied to the outside where they can contact the water beads. Maybe someone applied it to the inside in a misunderstanding. A call to Rain-Ex might be the ticket.
One other possibility is residue from coolant leaking from a bad heater core. Any smell of antifreeze? I had this issue on another car but ordinary window cleaner was effective until the stop leak I put in the rad sealed the leak.
Spock
"Live long and prosper"
You all do realize this topic is 2 years old and the OP hasn't logged into the site since 4/2014 right? It looks as though the 'film' could be window tint residue being on the INSIDE of the window. Not that it makes a difference being that the OP has probably moved on by now.......
One more thing to try: Warm water with liquid dish soap and a Mr. Clean Magic Eraser pad. Don't laugh; its amazing what those cleaning pads can do.
Spock
Spock
It is.... look at my 2003's project thread and you'll see. But again...... pointless offering suggestions on a topic this old, to a user that has not logged into the site in about 1.5 years...
1 - 20 of 21 Posts
