Hey,
I'm having trouble keeping my front door covers attached. Those little plastic fasteners that are spaced around the rim of the cover, are worn out. Does anyone know where I could get some new replacements. thanks Joe
Ford dealer. Get about 10 per door. They often get bent when putting them on at the factory so when you take the door panel off replace them all. Oh, also get an upholstery removal tool for it if you don't have it yet. Once you get all the screws taken off and all the plastic fasteners loosened you will have to use some force to pull the panel off.
Just bought a bag this weekend...12 in a bag @ 65 cents a piece from the dealer. Came out to about $8.
Oh yeah, get the black ones - they also have blue ones which are slightly shorter IMO. The blue ones might have a little bit of trouble catching onto the hole if you put extra sound insulation in between the doors (like I did).
Originally posted by 93taurusSX@Mar 23 2004, 08:33 PM Just bought a bag this weekend...12 in a bag @ 65 cents a piece from the dealer. Came out to about $8.
IIRC, it was about 12 clips for the front doors, definitely less for the rear doors (9-10 maybe). I only bought 12 because you can reuse a majority of the clips, and I only replaced the ones that were definitely stripped and held the doors are key points (like in the middle, were the panel has a tendency to bulge out without a clip).
