1 - 9 of 9 Posts
I have a 2002 Sable with DOHC engine. It started idling fast. In park if you accelerate and let off it stops at about 1500 rpm for about 1 or 2 minutes before it drops to 1000 rpm. If you are driving it will cruise at 35mph without any petal.
tps maybe the cause, tb getting stuck, vac leak. would check the tb and see if it is returning to close when foot off pedal. then check the tps.
tps = throttle position sensor
Is your check engine light on? My suggestion is try the easy things 1st - try cleaning the throttle body plate with specific cleaner made for tb's.
Yes the check engine light is on now P1506 Idle air controller valve overspeed error. So I replaced the Idle air control valve, but this did not change the problem. I can try to clean the throttle body first.
This is true, but I didn't. I cleaned the throttle body but it still idles fast. I also changed to TPS. Still no good. What are my next options?
Have you checked to see that the throttle butterfly is completely closed?
Sometimes curise cable keeps it from going to true idle.
Others mentioned vacuum leaks and I second that.
-chaft-
1 - 9 of 9 Posts
