1 - 20 of 20 Posts
I'm sure I'm not the only one who has this problem;
How can I make these look new again? Or even, how can I stop them from getting worse then they already are?
Anyone used Mothers Back to Black?
I use tire shine and they look like new. But it washes off with the first big rain.
Theres a thread I believe down in cleaning and detail, its possible to take those pillars off, re-prime and re-paint them with a nice gloss black, pop em back on, and it will look good as new! :thumb:
scratch out will work for 1.92 at wal-mart it take several times though would work best with polish wheel. also good for headlights. cleared mine right up
Tire shine is just an oil that sits on top that makes it glossy. Not a very good long term solution, but it won't harm it.
Paul or Daniel used some kind of paint that turned out pretty well.
Mike
:dunno:
I used Mother's Back to Black on mine a few days ago.
It worked well, it gives the pillars and trim a glossy look but someone who knows what they are looking for can still see the spots at close inspection.
It does wash off in the rain a little, but there's enough in the bottle for many more applications.
In short, Back to Black is not a permanent solution. Paint is... do a search for "faded trim" or something of the sort in the detailing forum and you should find what you're looking for.
Discussion Starter #13
QUOTE (OldWagon @ May 17 2009, 02:24 PM) index.php?act=findpost&pid=725894
Plus, being carbon fiber, they'll reduce weight as well... :p[/b]
Oh of course, of course. :lol2:
After searching in the detailing forum I found a similar post. But he was looking for something to restore his weatherstripping more than anything. I'm gonna try Mother's Back to Black for now and move from there. I'm a bit skeptical about painting them, as I don't want to make them look unnatural, or have them peel or anything like that.
Kidding aside, Duplicolor makes a Trim Black rattle can paint that works fairly well, mainly because it's between flat black and semi-gloss in surface finish, and the pigment load is very light.
If you try to paint a white surface, it takes a long time to reach past a light gray. But since the coloration is light, the paint is in reality mainly the surface effect, which ends up being a nice semi-gloss like the original. Since it's going over black (yes, you have faded gray right now, but the new paint surface + the slight pigmentation brings it all back), it looks fine.
Discussion Starter #15
QUOTE (OldWagon @ May 17 2009, 04:13 PM) index.php?act=findpost&pid=725917
If you try to paint a white surface, it takes a long time to reach past a light gray. But since the coloration is light, the paint is in reality mainly the surface effect, which ends up being a nice semi-gloss like the original. Since it's going over black (yes, you have faded gray right now, but the new paint surface + the slight pigmentation brings it all back), it looks fine.[/b]
I'm going to have to give this a try. Now I'm just thinking about how I'm going to paint them without getting any on the rest of the car. Taping off will only do so well...
I've got a whole bunch of fiberglass stuff here, that looks like an interesting project. And i got it all for free, so it'll only cost me time. :p
I had the same exact problem with mine i decided to paint them black i used Dupicolor engine enamel i had a can in the garage and figured to give it a try i masked off my whole car with plastic paper and just had those i sanded them down washed them with rubbing alcohol and did like 3 real light coats of black and 5 light mists of clear coat and let it sit for the day they look great
1 - 20 of 20 Posts
