1 - 2 of 2 Posts
Hello eveyone! Need some help again please. I noticed there are scratches on the inside tint of my rear door windows. How can i fix this? Is it possibe? My clear coat is also sterting to peel in areas. Is it possible to touch this up or should I repaint? Thanks all,your time is greatly apprecited. potts:}
Tint is usually a film so I believe it will require removal and re-tinting.
As for the clearcoat, you would most likely have to respray the entire panel to have it look right. That isn't cheap, but it's up to you if you want to get that fixed.
1 - 2 of 2 Posts
