Hello,
I am looking at new tires for a Gen 3 SHO with stock 16 inch chrome 6 ½ wide rims. Like many of you, I have been happy with the Continental ContiExtremeContact.
Is anyone running P245/50R16 instead of the OEM P225/55R16 on the stock rims. The wider tire (245/50) is a little heavier, nearly the same height but the recommended rim width is wider (7.0 to 8.5). If so, has the extra ¾ of an inch (20mm) caused any problems? Rubbing? Thanks. -- SJP
Specifications sheet from Continental Tire Website
http://www.conti-online.com/generator/www/...atasheet_en.pdf
Stock Tire - 225/55R16 >Search Tires
Tire 1 - 245/50R16 >Search Tires
Section Width: 8.85 in 225 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: 6 - 8 in
Rim Width Range: 7 - 8.5 in
Overall Diameter: 25.74 in 653.79 mm
Overall Diameter: 25.64 in 651.25 mm
Sidewall Height: 4.87 in 123.69 mm
Sidewall Height: 4.82 in 122.42 mm
Radius: 12.87 in 326.89 mm
Radius: 12.82 in 325.62 mm
Circumference: 80.86 in 2053.8 mm
Circumference: 80.55 in 2045.9 mm
Revs per Mile: 808.0
Revs per Mile: 811.2
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.2 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.396% too fast
Diameter Difference: - Diameter Difference: 0.39%
i have a 02 mercury sable. i wanna buy some 18 in rims by 7.5 in. do u think they will fit properly and what size low profile tire should i put on?
