21 - 21 of 21 Posts
There aren't any defined ranges because those ranges can vary widely depending on many factors.
For the MAF, you generally want to see about 0.5 lb/min at idle (~700 RPM). At 2500 RPM cruise the value may be around 3.7 lb/min. And at WOT you should be able to hit 15-17 lb/min passing the torque peak.
This image should sum up TPS readings:
Fully closed it should read just under a volt or about 18% and at full travel it should hit about 4.5 volts or 90%.
If you can post a data log in spreadsheet form I can take a look at it.
So I have a p0 430 if I did this or you able to help me as well
21 - 21 of 21 Posts
