I have an `04 Taurus and I'm having a problem with the AC condensate drain making it's way back into the passenger compartment and soaking the floor insulation. I've tried to clear the drain tube but it doesn't seem to be clogged. Any suggestions?
I happened to find that after searching a while... looks like pretty good info. Now I have to see if I can find the "dum dum" anywhere around here...Check under common problems/solutions. Common for outside water to leak into the vehicle through that extremely poorly designed drain with a spongey foam gasket. There's a thread entitled "I have the curse". Good info in there![]()
