I had an old thread discussing an intake leak, and after months of trying to hunt this down I finally got the car to throw a p0455 Evap large leak code. I believe I did have an intake leak and fixed that, because the car is better off now than before, but still somethings up so here's what I've done so far. 2005 Ford Taurus 3.0 Vulcan engine. Auto Climate.
New Evap purge valve under hood and vent solenoid on the canister, new Egr and tube (Old one broke, go figure) all lines and electrical connections checked on the canister, and under the hood as far as I can tell. I can't find a good diagram of where the Evap line runs from under the hood to the tank/canister? So I haven't checked that one. I plan on hooking my smoke tester to the system but not sure the best way to do that for evap. Can I hook it in the line going from the canister to the fuel tank? I don't want any of the smoke oil to get in the tank, not sure if it would hurt anything there. New gas cap btw, and as far as I can tell the filler neck all looks good. Thought about popping it off to check the seal, but didn't want to accidentally cause another leak. Any suggestions on this system?
Car has 125k miles and symptoms are grumpy idle, loss of vacuum at high rpm (Vents blow out defrost), when letting off the gas above 50-55mph the rpms go down to 900 and bounces up and down until the car has slowed under about 45-40mph.
Edit-car doesn't have much if any odor btw. If anything, the exhaust from the pipe smells a little more yuck, but could just be me.
