1 - 2 of 2 Posts
I am having trouble tracking down where i am getting fumes inside the car from. I have replaced the charcoal canister the fuel purge solenoid and the vapor canister located on the firewall. Any ideas? Thanks
Do you have any EVAP codes? If not, the EVAP system is intact and functioning correctly. EVAP system will set a code for a VERY VERY small leak (as small as a .020" diameter leak). I would suspect slightly leaking injector O rings, leaking VC gasket, etc.
1 - 2 of 2 Posts
