I had similar problems with our Taurus... it also ran well when cold but when it got warm it ran rich with black smoke. It also didn't want to start when engine was warm. These problems started straight after I overhauled the transmission (AXOD). It was strange because before the overhaul the engine worked just fine :huh:
I thought it must have something to do with the thing that I had removed the engine for transmission overhaul. So I checked all the electrical connectors of the engine and found out that the Coolant Temperature Sensor connector was loose. I pushed it in and that's it: it started to run normally, hot and cold :banana:
It seems to me that Your car has similar symptoms so I would first check that sensor and its connector. Seems like Your engine doesn't get the temperature information correctly...
