Hello all!
A month ago, I was getting a squealing around 3400-4000 RPM accompanied by a slow leak from the tranny pan. I just fixed the leak in my pan by using a non-hardening Permatex and the problem remains.
I'm getting the same squeal around 3400 RPM+. Did some reading/researching and wanted to run by a couple ideas for a differential diagnosis by more seasoned minds.
My thoughts...
1) some crap get into the tranny fluid?
2) ERG valve?
3) DPFE sensor?
4) dirty spark plugs misfiring?
For a full confession, I haven't replaced my PCV or my spark plugs at the recommended times per the manual. I'm @ 112K and it runs well under 3000 RPM, just have to accelerate a little slower. Will still get to high speeds (85+), problem only comes when RPMs are in that range.
Do you know how old the cam synchro is? They like to make noise when they are going bad. Do NOT use a dorman replacement if you pull out the synchro and it's bad. Buy a Motorcraft one.
Sent from AutoGuide.com App
I'm not sure whether my elderly great-aunt had it serviced or not. I going to assume it's the original part.
Will do on the Motorcraft parts. Only way to go.
Just watched a video on replacing the cam syncro.
To help others out and for clarification, might try to snap a video of the problem since it happens consistently.
Id have a video or atleast a write up if I had a Vulcan. There may be a write up on the forum. Just make sure your part is bad. The synchro having play is a dead give away of it being bad.
2000 Ford Taurus Diagnostic Data
I used a diagnostic tool to check for problem codes while revving engine in park with pedal to the floor. No problem codes were given. This is the raw data that I saved. It's rather lengthy but I did take the time to bold the RPM which serve as data points.
Recorded Data
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1170
CALC LOAD % 41.9
MAF FLOW GR/SE 9.82
COOLANT F 98
IAT F 71
IGN ADVANCE DE 10.0
ST FTRM1 % 2.3
LT FTRM1 % 0.7
ST FTRM2 % -1.0
LT FTRM2 % 0.7
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.730
ST FTRM11 % 0.8
O2S12 V 0.000
O2S21 V 0.730
ST FTRM21 % 0.8
O2S22 V 0.000
OBD2 STAT US
Frame -5 Time -3.8
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1168
CALC LOAD % 41.5
MAF FLOW GR/SE 9.50
COOLANT F 100
IAT F 71
IGN ADVANCE DE 10.0
ST FTRM1 % -1.0
LT FTRM1 % 0.0
ST FTRM2 % 0.7
LT FTRM2 % 0.7
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.450
ST FTRM11 % 0.7
O2S12 V 0.000
O2S21 V 0.830
ST FTRM21 % 0.8
O2S22 V 0.000
OBD2 STAT US
Frame -4 Time -3.1
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1148
CALC LOAD % 42.3
MAF FLOW GR/SE 9.34
COOLANT F 102
IAT F 71
IGN ADVANCE DE 10.0
ST FTRM1 % 2.3
LT FTRM1 % 0.7
ST FTRM2 % 0.0
LT FTRM2 % 0.7
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.825
ST FTRM11 % -2.2
O2S12 V 0.000
O2S21 V 0.455
ST FTRM21 % 0.0
O2S22 V 0.000
OBD2 STAT US
Frame -3 Time -2.3
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1127
CALC LOAD % 42.3
MAF FLOW GR/SE 9.03
COOLANT F 102
IAT F 71
IGN ADVANCE DE 10.5
ST FTRM1 % 0.0
LT FTRM1 % 0.0
ST FTRM2 % -2.2
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.260
ST FTRM11 % 0.7
O2S12 V 0.000
O2S21 V 0.815
ST FTRM21 % -3.4
O2S22 V 0.000
OBD2 STAT US
Frame -2 Time -1.6
MIL STATUS OFF
ABSLT TPS % 15.6
ENG SPEED RPM 1052
CALC LOAD % 41.9
MAF FLOW GR/SE 8.44
COOLANT F 102
IAT F 71
IGN ADVANCE DE 10.5
ST FTRM1 % 2.3
LT FTRM1 % 0.0
ST FTRM2 % 0.7
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.575
ST FTRM11 % 0.7
O2S12 V 0.000
O2S21 V 0.710
ST FTRM21 % 0.0
O2S22 V 0.000
OBD2 STAT US
Frame -1 Time -0.8
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1032
CALC LOAD % 41.1
MAF FLOW GR/SE 8.23
COOLANT F 104
IAT F 71
IGN ADVANCE DE 10.5
ST FTRM1 % 0.8
LT FTRM1 % 1.5
ST FTRM2 % 0.7
LT FTRM2 % 2.3
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.855
ST FTRM11 % -1.0
O2S12 V 0.000
O2S21 V 0.765
ST FTRM21 % -2.2
O2S22 V 0.000
OBD2 STAT US
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 15.6
ENG SPEED RPM 961
CALC LOAD % 40.7
MAF FLOW GR/SE 7.18
COOLANT F 105
IAT F 71
IGN ADVANCE DE 10.5
ST FTRM1 % 0.0
LT FTRM1 % 3.1
ST FTRM2 % -2.2
LT FTRM2 % 3.1
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.770
ST FTRM11 % 0.8
O2S12 V 0.000
O2S21 V 0.735
ST FTRM21 % 0.8
O2S22 V 0.000
OBD2 STAT US
Frame 1 Time 0.8
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 890
CALC LOAD % 41.5
MAF FLOW GR/SE 6.65
COOLANT F 105
IAT F 71
IGN ADVANCE DE 10.5
ST FTRM1 % -3.4
LT FTRM1 % 3.9
ST FTRM2 % -1.0
LT FTRM2 % 3.1
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.105
ST FTRM11 % 0.7
O2S12 V 0.000
O2S21 V 0.485
ST FTRM21 % 0.0
O2S22 V 0.000
OBD2 STAT US
Frame 2 Time 1.6
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 871
CALC LOAD % 41.1
MAF FLOW GR/SE 6.49
COOLANT F 107
IAT F 71
IGN ADVANCE DE 11.0
ST FTRM1 % 0.0
LT FTRM1 % 3.9
ST FTRM2 % -1.0
LT FTRM2 % 3.1
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.745
ST FTRM11 % -2.2
O2S12 V 0.000
O2S21 V 0.330
ST FTRM21 % 6.2
O2S22 V 0.000
OBD2 STAT US
Frame 3 Time 2.3
MIL STATUS OFF
ABSLT TPS % 19.6
ENG SPEED RPM 1224
CALC LOAD % 46.2
MAF FLOW GR/SE 9.82
COOLANT F 109
IAT F 71
IGN ADVANCE DE 16.5
ST FTRM1 % 2.3
LT FTRM1 % 0.0
ST FTRM2 % 3.1
LT FTRM2 % -2.2
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.095
ST FTRM11 % 2.3
O2S12 V 0.000
O2S21 V 0.900
ST FTRM21 % 0.8
O2S22 V 0.005
OBD2 STAT US
Frame 4 Time 3.1
MIL STATUS OFF
ABSLT TPS % 22.7
ENG SPEED RPM 2015
CALC LOAD % 37.2
MAF FLOW GR/SE 15.42
COOLANT F 109
IAT F 71
IGN ADVANCE DE 31.5
ST FTRM1 % -1.0
LT FTRM1 % -3.4
ST FTRM2 % -1.0
LT FTRM2 % -2.2
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.750
ST FTRM11 % -4.6
O2S12 V 0.005
O2S21 V 0.210
ST FTRM21 % 0.7
O2S22 V 0.005
OBD2 STAT US
Frame 5 Time 3.8
MIL STATUS OFF
ABSLT TPS % 24.3
ENG SPEED RPM 2568
CALC LOAD % 32.1
MAF FLOW GR/SE 16.89
COOLANT F 109
IAT F 71
IGN ADVANCE DE 36.0
ST FTRM1 % 1.5
LT FTRM1 % -1.0
ST FTRM2 % 0.8
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.515
ST FTRM11 % 0.8
O2S12 V 0.005
O2S21 V 0.120
ST FTRM21 % 3.1
O2S22 V 0.015
OBD2 STAT US
Frame 6 Time 4.6
MIL STATUS OFF
ABSLT TPS % 25.8
ENG SPEED RPM 2896
CALC LOAD % 32.9
MAF FLOW GR/SE 19.54
COOLANT F 111
IAT F 71
IGN ADVANCE DE 36.0
ST FTRM1 % 0.8
LT FTRM1 % -1.0
ST FTRM2 % -2.2
LT FTRM2 % 0.7
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.385
ST FTRM11 % -4.6
O2S12 V 0.025
O2S21 V 0.180
ST FTRM21 % 2.3
O2S22 V 0.035
OBD2 STAT US
Frame 7 Time 5.3
MIL STATUS OFF
ABSLT TPS % 28.2
ENG SPEED RPM 3263
CALC LOAD % 34.9
MAF FLOW GR/SE 23.87
COOLANT F 111
IAT F 71
IGN ADVANCE DE 36.0
ST FTRM1 % -2.2
LT FTRM1 % 0.8
ST FTRM2 % -3.4
LT FTRM2 % 2.3
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.715
ST FTRM11 % -1.0
O2S12 V 0.040
O2S21 V 0.320
ST FTRM21 % 0.7
O2S22 V 0.065
OBD2 STAT US
Frame 8 Time 6.1
MIL STATUS OFF
ABSLT TPS % 29.8
ENG SPEED RPM 3813
CALC LOAD % 34.5
MAF FLOW GR/SE 28.94
COOLANT F 113
IAT F 71
IGN ADVANCE DE 36.0
ST FTRM1 % -2.2
LT FTRM1 % 0.0
ST FTRM2 % -2.2
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 288
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.110
ST FTRM11 % -5.1
O2S12 V 0.045
O2S21 V 0.785
ST FTRM21 % -7.5
O2S22 V 0.085
OBD2 STAT US
Frame 9 Time 6.8
MIL STATUS OFF
ABSLT TPS % 30.9
ENG SPEED RPM 3974
CALC LOAD % 34.9
MAF FLOW GR/SE 31.10
COOLANT F 114
IAT F 71
IGN ADVANCE DE 36.5
ST FTRM1 % -10.4
LT FTRM1 % 0.0
ST FTRM2 % -7.7
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.060
ST FTRM11 % -9.2
O2S12 V 0.050
O2S21 V 0.185
ST FTRM21 % -7.5
O2S22 V 0.105
OBD2 STAT US
Frame 10 Time 7.6
MIL STATUS OFF
ABSLT TPS % 30.9
ENG SPEED RPM 3993
CALC LOAD % 35.6
MAF FLOW GR/SE 31.79
COOLANT F 116
IAT F 71
IGN ADVANCE DE 36.5
ST FTRM1 % -7.5
LT FTRM1 % 0.0
ST FTRM2 % -4.6
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 291
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.135
ST FTRM11 % -9.2
O2S12 V 0.055
O2S21 V 0.055
ST FTRM21 % -8.0
O2S22 V 0.115
OBD2 STAT US
Frame 11 Time 8.3
MIL STATUS OFF
ABSLT TPS % 29.8
ENG SPEED RPM 3993
CALC LOAD % 30.1
MAF FLOW GR/SE 27.56
COOLANT F 118
IAT F 71
IGN ADVANCE DE 38.0
ST FTRM1 % 1.5
LT FTRM1 % 0.8
ST FTRM2 % 0.8
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.915
ST FTRM11 % -5.1
O2S12 V 0.295
O2S21 V 0.050
ST FTRM21 % 0.0
O2S22 V 0.230
OBD2 STAT US
Frame 12 Time 9.1
MIL STATUS OFF
ABSLT TPS % 22.3
ENG SPEED RPM 2518
CALC LOAD % 24.3
MAF FLOW GR/SE 13.09
COOLANT F 118
IAT F 71
IGN ADVANCE DE 40.0
ST FTRM1 % -4.9
LT FTRM1 % -1.0
ST FTRM2 % 0.7
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.860
ST FTRM11 % -3.4
O2S12 V 0.485
O2S21 V 0.850
ST FTRM21 % -4.6
O2S22 V 0.330
OBD2 STAT US
Frame 13 Time 9.8
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 1175
CALC LOAD % 22.7
MAF FLOW GR/SE 5.91
COOLANT F 120
IAT F 71
IGN ADVANCE DE 32.5
ST FTRM1 % -5.1
LT FTRM1 % 1.5
ST FTRM2 % 0.0
LT FTRM2 % 2.3
VEH SPEED MPH 0
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.080
ST FTRM11 % 0.7
O2S12 V 0.555
O2S21 V 0.215
ST FTRM21 % 0.0
O2S22 V 0.395
OBD2 STAT US
Frame 14 Time 10.6
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 949
CALC LOAD % 33.7
MAF FLOW GR/SE 5.38
COOLANT F 122
IAT F 71
IGN ADVANCE DE 30.5
ST FTRM1 % 3.1
LT FTRM1 % 1.5
ST FTRM2 % 0.7
LT FTRM2 % 3.1
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.885
ST FTRM11 % 0.8
O2S12 V 0.600
O2S21 V 0.860
ST FTRM21 % 0.8
O2S22 V 0.445
OBD2 STAT US
Frame 15 Time 11.3
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 868
CALC LOAD % 32.9
MAF FLOW GR/SE 4.80
COOLANT F 123
IAT F 71
IGN ADVANCE DE 30.0
ST FTRM1 % 0.0
LT FTRM1 % 3.9
ST FTRM2 % 0.7
LT FTRM2 % 4.6
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.045
ST FTRM11 % 2.3
O2S12 V 0.625
O2S21 V 0.085
ST FTRM21 % 3.1
O2S22 V 0.485
OBD2 STAT US
Frame 16 Time 12.1
MIL STATUS OFF
ABSLT TPS % 16.0
ENG SPEED RPM 824
CALC LOAD % 34.9
MAF FLOW GR/SE 4.48
COOLANT F 125
IAT F 71
IGN ADVANCE DE 28.5
ST FTRM1 % -1.0
LT FTRM1 % 4.6
ST FTRM2 % 0.7
LT FTRM2 % 3.9
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.865
ST FTRM11 % -1.0
O2S12 V 0.655
O2S21 V 0.160
ST FTRM21 % 3.1
O2S22 V 0.520
OBD2 STAT US
Frame 17 Time 12.8
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 1227
CALC LOAD % 37.2
MAF FLOW GR/SE 6.39
COOLANT F 125
IAT F 71
IGN ADVANCE DE 42.0
ST FTRM1 % -2.2
LT FTRM1 % 1.5
ST FTRM2 % 2.3
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.120
ST FTRM11 % 1.5
O2S12 V 0.670
O2S21 V 0.100
ST FTRM21 % 1.5
O2S22 V 0.555
OBD2 STAT US
Frame 18 Time 13.5
MIL STATUS OFF
ABSLT TPS % 20.0
ENG SPEED RPM 1405
CALC LOAD % 37.2
MAF FLOW GR/SE 7.81
COOLANT F 127
IAT F 71
IGN ADVANCE DE 43.0
ST FTRM1 % 0.7
LT FTRM1 % 0.8
ST FTRM2 % -2.2
LT FTRM2 % 0.0
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.080
ST FTRM11 % 1.5
O2S12 V 0.675
O2S21 V 0.480
ST FTRM21 % 0.0
O2S22 V 0.595
OBD2 STAT US
Frame 19 Time 14.3
MIL STATUS OFF
ABSLT TPS % 21.5
ENG SPEED RPM 1726
CALC LOAD % 32.5
MAF FLOW GR/SE 10.13
COOLANT F 127
IAT F 71
IGN ADVANCE DE 43.5
ST FTRM1 % 0.7
LT FTRM1 % -2.2
ST FTRM2 % 3.9
LT FTRM2 % -4.6
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.865
ST FTRM11 % -2.2
O2S12 V 0.700
O2S21 V 0.885
ST FTRM21 % -3.4
O2S22 V 0.630
OBD2 STAT US
Frame 20 Time 15.0
MIL STATUS OFF
ABSLT TPS % 22.3
ENG SPEED RPM 1985
CALC LOAD % 31.7
MAF FLOW GR/SE 11.40
COOLANT F 127
IAT F 73
IGN ADVANCE DE 44.5
ST FTRM1 % 0.0
LT FTRM1 % -1.0
ST FTRM2 % -6.3
LT FTRM2 % 2.3
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.170
ST FTRM11 % 0.7
O2S12 V 0.680
O2S21 V 0.390
ST FTRM21 % -2.2
O2S22 V 0.625
OBD2 STAT US
Frame 21 Time 15.8
MIL STATUS OFF
ABSLT TPS % 23.5
ENG SPEED RPM 2269
CALC LOAD % 29.8
MAF FLOW GR/SE 13.88
COOLANT F 129
IAT F 73
IGN ADVANCE DE 45.5
ST FTRM1 % -1.0
LT FTRM1 % -2.2
ST FTRM2 % 0.8
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.145
ST FTRM11 % 0.0
O2S12 V 0.560
O2S21 V 0.690
ST FTRM21 % -4.9
O2S22 V 0.370
OBD2 STAT US
Frame 22 Time 16.5
MIL STATUS OFF
ABSLT TPS % 24.3
ENG SPEED RPM 2430
CALC LOAD % 30.5
MAF FLOW GR/SE 14.73
COOLANT F 129
IAT F 73
IGN ADVANCE DE 46.0
ST FTRM1 % -4.6
LT FTRM1 % -1.0
ST FTRM2 % 2.3
LT FTRM2 % -1.0
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.310
ST FTRM11 % 1.5
O2S12 V 0.170
O2S21 V 0.750
ST FTRM21 % 0.7
O2S22 V 0.080
OBD2 STAT US
Frame 23 Time 17.3
MIL STATUS OFF
ABSLT TPS % 25.0
ENG SPEED RPM 2668
CALC LOAD % 29.8
MAF FLOW GR/SE 15.73
COOLANT F 129
IAT F 73
IGN ADVANCE DE 48.0
ST FTRM1 % 1.5
LT FTRM1 % -1.0
ST FTRM2 % -1.0
LT FTRM2 % 0.8
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.875
ST FTRM11 % -4.6
O2S12 V 0.110
O2S21 V 0.320
ST FTRM21 % 0.7
O2S22 V 0.110
OBD2 STAT US
Frame 24 Time 18.0
MIL STATUS OFF
ABSLT TPS % 25.8
ENG SPEED RPM 2910
CALC LOAD % 31.7
MAF FLOW GR/SE 18.37
COOLANT F 131
IAT F 73
IGN ADVANCE DE 47.5
ST FTRM1 % -3.4
LT FTRM1 % -1.0
ST FTRM2 % 1.5
LT FTRM2 % 0.7
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.580
ST FTRM11 % 0.8
O2S12 V 0.075
O2S21 V 0.860
ST FTRM21 % 1.5
O2S22 V 0.090
OBD2 STAT US
Frame 25 Time 18.8
MIL STATUS OFF
ABSLT TPS % 27.0
ENG SPEED RPM 3164
CALC LOAD % 30.9
MAF FLOW GR/SE 20.17
COOLANT F 132
IAT F 73
IGN ADVANCE DE 47.5
ST FTRM1 % -3.4
LT FTRM1 % 0.8
ST FTRM2 % 0.0
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.180
ST FTRM11 % 0.0
O2S12 V 0.060
O2S21 V 0.840
ST FTRM21 % -4.6
O2S22 V 0.110
OBD2 STAT US
Frame 26 Time 19.5
MIL STATUS OFF
ABSLT TPS % 27.8
ENG SPEED RPM 3378
CALC LOAD % 31.3
MAF FLOW GR/SE 22.44
COOLANT F 134
IAT F 73
IGN ADVANCE DE 47.5
ST FTRM1 % 2.3
LT FTRM1 % 0.8
ST FTRM2 % 0.8
LT FTRM2 % 3.1
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.275
ST FTRM11 % 0.7
O2S12 V 0.080
O2S21 V 0.140
ST FTRM21 % 0.7
O2S22 V 0.085
OBD2 STAT US
Frame 27 Time 20.3
MIL STATUS OFF
ABSLT TPS % 28.6
ENG SPEED RPM 3610
CALC LOAD % 31.3
COOLANT F 134
IAT F 73
IGN ADVANCE DE 47.5
ST FTRM1 % -3.4
LT FTRM1 % 0.8
ST FTRM2 % -3.4
LT FTRM2 % 2.3
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.200
ST FTRM11 % -1.0
O2S12 V 0.085
O2S21 V 0.845
ST FTRM21 % 0.0
O2S22 V 0.120
OBD2 STAT US
Frame 28 Time 21.0
MIL STATUS OFF
ABSLT TPS % 29.4
ENG SPEED RPM 3828
CALC LOAD % 31.7
MAF FLOW GR/SE 26.24
COOLANT F 136
IAT F 75
IGN ADVANCE DE 48.0
ST FTRM1 % 1.5
LT FTRM1 % 0.8
ST FTRM2 % -4.6
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.375
ST FTRM11 % -8.0
O2S12 V 0.055
O2S21 V 0.065
ST FTRM21 % -4.6
O2S22 V 0.050
OBD2 STAT US
Frame 29 Time 21.8
MIL STATUS OFF
ABSLT TPS % 30.1
ENG SPEED RPM 3968
CALC LOAD % 32.1
MAF FLOW GR/SE 27.88
COOLANT F 138
IAT F 75
IGN ADVANCE DE 48.5
ST FTRM1 % -1.0
LT FTRM1 % 0.0
ST FTRM2 % -7.5
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.055
ST FTRM11 % -8.0
O2S12 V 0.040
O2S21 V 0.045
ST FTRM21 % -7.7
O2S22 V 0.045
OBD2 STAT US
Frame 30 Time 22.5
MIL STATUS OFF
ABSLT TPS % 30.5
ENG SPEED RPM 3974
CALC LOAD % 32.1
MAF FLOW GR/SE 29.09
COOLANT F 140
IAT F 75
IGN ADVANCE DE 48.5
ST FTRM1 % -8.0
LT FTRM1 % 0.0
ST FTRM2 % -9.2
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 261
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.415
ST FTRM11 % -7.5
O2S12 V 0.045
O2S21 V 0.360
ST FTRM21 % -7.5
O2S22 V 0.045
OBD2 STAT US
Frame 31 Time 23.3
MIL STATUS OFF
ABSLT TPS % 30.5
ENG SPEED RPM 4000
CALC LOAD % 32.5
MAF FLOW GR/SE 28.57
COOLANT F 141
IAT F 75
IGN ADVANCE DE 46.5
ST FTRM1 % -7.7
LT FTRM1 % 0.0
ST FTRM2 % -7.7
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
O2S11 V 0.425
ST FTRM11 % -6.3
O2S12 V 0.060
O2S21 V 0.150
ST FTRM21 % -2.2
O2S22 V 0.100
OBD2 STAT US
Frame 32 Time 24.0
MIL STATUS OFF
ABSLT TPS % 26.6
ENG SPEED RPM 3692
CALC LOAD % 23.9
MAF FLOW GR/SE 19.32
COOLANT F 143
IAT F 75
IGN ADVANCE DE 49.5
ST FTRM1 % -2.2
LT FTRM1 % 0.8
ST FTRM2 % -5.1
LT FTRM2 % 1.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.710
ST FTRM11 % -8.0
O2S12 V 0.790
O2S21 V 0.705
ST FTRM21 % -4.9
O2S22 V 0.720
OBD2 STAT US
Frame 33 Time 24.8
MIL STATUS OFF
ABSLT TPS % 23.5
ENG SPEED RPM 2820
CALC LOAD % 21.1
MAF FLOW GR/SE 12.99
COOLANT F 145
IAT F 73
IGN ADVANCE DE 49.5
ST FTRM1 % -3.4
LT FTRM1 % -5.1
ST FTRM2 % -5.1
LT FTRM2 % -2.2
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.640
ST FTRM11 % 0.8
O2S12 V 0.770
O2S21 V 0.075
ST FTRM21 % 0.7
O2S22 V 0.730
OBD2 STAT US
Frame 34 Time 25.5
MIL STATUS OFF
ABSLT TPS % 3.9
ENG SPEED RPM 835
CALC LOAD % 6.6
MAF FLOW GR/SE 74.57
COOLANT F 21
IAT F 55
IGN ADVANCE DE -36.1
ST FTRM1 % -51.0
LT FTRM1 % -14.5
ST FTRM2 % -10.4
LT FTRM2 % 85.9
VEH SPEED MPH 155
FUEL PRESS KPAG 762
FUEL SYS 1 OPEN2
FUEL SYS 2 CLSD1
O2S11 V 0.555
ST FTRM11 % 48.4
O2S12 V 1.010
O2S21 V 1.025
ST FTRM21 % -32.7
O2S22 V 0.990
OBD2 STAT N/A
Frame 773 Time -13.7
What the heck was going on in the last data frame? TPS is way low, MAF is high, coolant temp is 21ºF, timing is 36º ATDC, fuel trims are way high, and vehicle speed is 155 MPH?! Was the car actually running when that last one was recorded or is that some kind of scan tool glitch? The frame number is way different and the time is negative so that's why I hope it's a scan tool glitch.
Other than that I don't see anything wrong. PCM is using the timing advance to keep the engine idle a bit high while the engine warms up.
