Does anyone have access to an engine wiring diagram. I have a few wires that are disconnected, and I can't figure out where they plug back into. I would like to get this figured out as it may be causing an issue starting the car.
If you can show some pictures of the wire ends (connectors), maybe someone can help. Are you talking from an engine replacement? If it is what type and year engine?
just curious, what led up to having several wires disconnected?
Car's year and engine model will certainly shine some additional light on the problem.
Which wire at which connector is misplaced?
I will hopefully be able to get pictures tomorrow. It's a 95 Ford Taurus GL v6 3.8L. The wires were already disconnected when I bought the car.
Don't have anything on a 3,8...
Maybe you can describe a connector's location? wire colors?
Driver side of the engine bay. It's the little guy right by the trans dipstick. I believe brown and white. It literally only comes out of the firewall like two inches max.
So I may have found an issue, if not the issue. The pictures I'm posting currently are of the wiring that goes to my distributor. It looks like it's been cut and spliced together. If anyone has a proper wiring diagram of how it's supposed to be let me know. The wire is not covered and on doesnt connect to anything I believe. Any help appreciated.
