1 - 2 of 2 Posts
I have a 1996 Taurus LX with the Duratec, about 115000 miles. Car runs fine, and when in gear, idles at about 650rpm. When the car is warm, and I put it in park, the rpm's drop to 450-500rpm, and the engine stumbles a bit, but never stalls out. Sometimes it does this in reverse, too. The PCV valve and hose was replaced last September, and the IAC last August. I can't find any vacuum leaks, and there are no codes. Anyone have a similar problem or know how to fix it? Thanks.
May be the transmission range switch. This tells the PCM what gear you are in and adjust the air flow through the IAC. I would try to clean the connector first.
1 - 2 of 2 Posts
