I have a 99, and it has been running fine the last week (I just pulled it out of storage) and now it is running a little weird. When I was on the expressway yesterday, I was going about 70mph. I went to speed up to pass, but when I stepped on the gas, and the rpms got to 3500 the rpms kept dipping and going back up. At the same time, I was not able to accelerate. It did the same thing again today. Now it seems to be doing the same thing even from a dead stop.....Could this just be the old gas working itself out of the system?( I have only filled the tank twice since I started driving it agai) Or is this a much bigger issue? It sat for about 6 years, and only has 40,000 miles on it.....HELP!!!
Stop driving it until you can change the transmission fluid and filter! There's probably moisture in the transmission fluid, and it's making it slip. I would only use the flush procedure on this website as a power force flush can ruin an older transmission. I would also flush the coolant asap, as there's probably corrosion in there from sitting so long. Depending on how long it's been sitting, or if it has ever been done, I would also change the belt as well. Are the tires dry rotted or expired? I would flush the brake system, too.
if it has been sitting for 6 years i would change the fuel filter and air filter if you have not already done so. as for the current trouble i think i have heard similar problems with cats going out but i cant remember for sure
Are the actual engine RPM's going up and down, or is it the tach bouncing up and down? Tach bounce is a sign of a bad VSS on the transmission.
QUOTE (drh1957 @ Mar 7 2009, 11:07 AM) index.php?act=findpost&pid=706335
Are the actual engine RPM's going up and down, or is it the tach bouncing up and down? Tach bounce is a sign of a bad VSS on the transmission.[/b]
That's speedo bounce, not tach bounce.
Check the fuel pressure too. Pump might not be able to give out enough pressure under load.
