ok i have done alot of r&d and found a good new engine in the crate and a rebuilt tranny, and rack and pinion also is getting changed.
i have a 92 sable ls and am curious about what is needed to do to pull the engine and tranny out and also the rack and pinion. i am going to be doing this in a home garage so i cannot pull anything from the bottom excpet for maybe the tranny.
is there a how to on doing the engine/tranny/rack??
any pointers or suggestions on what i need or should do would help.
thanks
I'm in the process of pulling the engien and transmission out of an 89 Sable out the top, 3.0/AXOD I already have the engine out and a few bolts away from the transmission... basically, depending on the engine, you have to start taking stuff apart till it looks like it will come out it'd take to long to type out what exactly is needed and th steps, I have down the out/in on this car 5 times (I actually think that this is my 6th) so I can do it in a reasonable amount of time, but...... if you are new at this it'll take you close to 1 weekend to do the pull, and you need some specialty tools as well
editied for some mistakes
