Good afternoon
I have a 2013 Ford Taurus with I believe has a bad engine or transmission mount. Need to know what is the best way to determine which mount is bad. The engine is vibrating toward the rear when the transmission is put in drive. Tha ks
This is how i diagnosis a bad engine mount, with the hood open, > Foot firmly on the brake< start motor and put in drive, or low, and give it a little gas, till you see engine move, or rock a bit. If it doesn't move in drive, then try >reverse< and do the same thing, this would show you on at least the which motor mount is broke, as far as the tranny goes, you prolly can't see the transmission mounts, unless on a lift.
