Yes, theres an ad in the classifieds or you can pm me for details.
As for your swap, its doable, but your better off buying a totaled durated=c, as you will need the engine, wire harness, PCM, motor mounts, coolant tubing, collant resivor, power steering res, alternator, ac compressor (FS10), PS pump Water pump, serpintene belt, upper intake, lower intake, TB, Air intake Tubing, Y-Pipe, Headders, ETC. Itd doable, but MUCH MORE cost effective to buy a totaled care fror about 500-1K$$$. I baught back my LOADED duratec from the insurance co for $600, so you should be able to get one with some good searching for under a grand, plus, if the sub frame is not bent, you can just "drop and swap" the subframes and then you have minimal work.
Brad
