1 - 2 of 2 Posts
Hello I'm putting a 2001 24 Valve duratec into a 2000 ohv taurus and was wondering since I'm keeping the PCM with the engine will I have starting issues or will I have to swap PATS Modules as well?? Both cars have PATS....Any help is greatly appreciated thanks!
Not sure it will even run unless you swap computers also. Wiring harness will be different and different sensors especially the Cam Shaft Position Sensor is present in the OHV and not in the DOHC, It sets up the injector timing for the OHV so not sure how the injectors will work in the DOHC.
1 - 2 of 2 Posts
