Engine Oil: Selecting the Best for a Duratec
I spent quite a bit of time reviewing data and putting together the following matrix, in order to "bottom-line" what are the best engine oils out there. I hope you find this informative and helpful. It certainly impacted my decision making process.
Just in case the attachment doesn't come through the way I expect, the average of ordinal rankings were as follows: Amsoil (1.14), Valvoline SynPower (3.43), Mobil 1 (3.71), Castrol Syntec (4.57), Pennzoil Synthetic (5.14), Quaker State Synthetic (5.71), Quaker State Peak Performance (6.29), Castrol GTX Drive Hard (6.57), Valvoline (6.71), Mobil Drive Clean (7.00), and Pennzoil with Purebase (7.14). The lower the number, the better the oil is overall. Seven tests were run on each oil: Thin-Film Oxygen Uptake (ASTM D-4742), High Temperature/High Shear (ASTM D-4683), NOACK Volatility (ASTM D-5800), Pour Point (ASTM D-97), Total Base Number (ASTM D-2896), Cold Cranking Simulator (ASTM D-5293), and Four-Ball Wear (ASTM D-4172). Each oil was ranked by test, in order to come up with an overall "Average of Ordinal Rankings."
European oil torture tests are probably the toughest in the world for an oil to pass. In the U.S., the oil industry establishes the standards; however, in Europe the automobile industry does (the Association des Constructeurs Europeens d'Automobiles or ACEA). The toughest of the tough are, in my opinion, Mercedes-Benz'.
Like many of you, I'm looking for the best oil out there. In my opinion, that is Amsoil. I'll tell you why. Not only is it in a league by itself in the "API Motor Oil Testing: 10W-30" results, it is the only manufacturer of 5W-30 and 10W-30 engine oil that I know of that contains an ACEA A3 rating and has passed Mercedes-Benz' 229.3 tests. This is no small task. Neither Valvoline nor Mobil 1 can claim this distinction. An ACEA A3 rating is tough to get and is defined by, "Stable, stay-in-grade oil intended for use in high performance gasoline engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of low viscosity oils, and/or for severe operating conditions as defined by the engine manufacturer." Similarly, MB sheet 229.3 approved oils are, " for passenger cars with gas and deisel engines with extended drain interval indicator FSS up to 20,000 km, or 40,000 km-25,000 mi, min. 1.0% fuel saving compared to 229.1, Base ACEA A3 B3." I run Amsoil 5W-30 with a SDF-11 filter in my Duratec . . . it's awesome. It meets not only Ford's oil requirements, but almost everyone else's too. It's all about adding that "margin of safety" in life.
