What's on the car (front mount) looks just like the picture of a new one on internet, no sagging, no cracking. Is it okay then?
The top anchor strut (torque strut, top engine mount, or dog bone) is shot. I just want to know if I have to replace the engine mount as well.
If it looks fine and no excessive rocking of the engine, it should be fine. The older models don't have the torque strap.
Thanks for the reply.
I have read many posts here on engine mount replacement. The posters said their engine mount was "shot." If an engine mount is shot, does it get visibly deformed? I am not sure if their diagnosis was based on engine movement or visible deformation. But I remember someone saying that if the dog bone is damaged, it's because the engine mount is damaged. It makes sense.
I cannot check engine movement right now because the car is partially disassembled. That's why I am asking this stupid question. Thanks.
My dog bone is "shot": the rubber is cracked and a large piece is missing.
iirc, the engine mounts are filled with a fluid. Most failures occure when the mounds start to leak the fluid.. I'm pretty sure it was the e-mounts that were fluid. :headscratch:
Thanks. So engine rocking test seems to be a more reliable way to spot a worn-out engine mount. As soon as I am done with the repair, I will do the test.
