So I think that I've reached the end of the story. I'm probably going to blog about a bunch. There's things that were hard that were not well explained here or elsewhere.
The YouTube video was quite helpful, but skips a lot of detail.
There is little help on the installation of the injectors --- which is quite tricky, but I managed on the 4th try to get it right.
In the end, originally, I had a problem with loss of power ... so bad that the car had trouble climbing a hill (and this was in the middle of a 5 hour trip). The most likely cause was spark plugs. Maintenance schedule says 200k km, but they were quite bad (chipped, etc) at 180k km.
But changing the spark plugs required removing the pleanum... which either didn't get back on right or ended up disturbing the already deteriorated lower intake gaskets.
Repairing the lower intake gaskets required removing the fuel rail and injectors --- which is a pain in the a** assembly that is tricky to reinstall correctly --- my first 3 attempts resulted in leaking gas. Not good.
So after 4 days of practice, I'm really good at stripping and redoing my intake system.
Takeaway: the people who design these infernal machines should have to work on them once in awhile.
