QUOTE (ricer333 @ Jul 23 2009, 12:10 PM)
index.php?act=findpost&pid=741418
QUOTE (sfhess @ Jul 22 2009, 02:40 PM)
index.php?act=findpost&pid=741273
Um....
The battery does not give the alternator any current. Its primary purpose is to start the car and it supplies power to the accessories etc when the engine is not running. After the engine is running the alternator supplies electricity to the car's systems and replenishes the battery.
First thing I would check on anything electrical that is not working is the related fuse, then troubleshoot the rest of the circuit.[/b]
Is this true? I thought the battery ALWAYS supplied the power to the accessories and other electrical components in the car. I thought the Alternator was just there to ensure that the battery stayed charged while the battery was feeding all of these components.
I do agree that the battery does not give the alternator any current quote... just the rest of that paragraph is my question.
Thanks!
after the car is running the alternator takes over entirely unless the electrical demand is greater then the alternators output then the electrical system will take power from both the battery and alternator.
and the battery provides power when starting the car, or when the key is in accessory, and it also provides power to the alternator to get it started. (it takes power to make power)
as for pulling your car appart it shoould not be hard at all. i would bring a small socket set (maker sure it has metric sizes) and a few screwdrivers both phillips and flat heah of different sizez and lengths.
like sfhess said but you could try it on a car in the junkyard if you prefer. the only differences between your car and a car with an analog cluster would be that the analog car has a speedo cable and that is a pain to get off but you can learn everything else by taking an anolog car appart. just take your time and think about things if you are not sure and you should get it no problem
