98 Duratec SE
Ok, so I just got back from vacation. On the way to the airport last week i started having a weird problem with my gas tank warning light. Every 30 min or so it would flash on for about 2-3 sec, then turn off. No other symptoms accompanied this light. I had 1/2 tank at the time so I just left it at the parking lot and came back to it today. The problem was much more frequent this morning when i drove the car. In addition to the light turning on, there was an accompanying transmission down shift (rough). After a few seconds the transmission would up shift again and all would be fine...until it happened again. I stopped at a gas station since I had gone over 300 miles on that tank and it seemed like a good time to fill up. The problem disappeared after i got back in the car....for a while. About an hour later it started doing it again. I found that if i flashed my high beams, it would trigger the symptoms. As i get closer to home i notice that my radio display is flickering a little. This is exacerbated when i flash my high beams. Finally, when i turn to go into my neighborhood, all my electronics shut off. The car still ran, but i did lose power steering for a brief period. All the electronics did return pretty quickly, but this can't be good. The only other related problem i've had is that twice when i went to back out of a parking space I lost power steering and the charge light came on on my dash. Any ideas? I know it's a lot going on. I'm thinking of just paying the $75 to get the diagnostic done at a dealership.
