I am usaully the one that post replies to this code as I have worked the problem in the past but I just got the code again on my 96 Duratec. The car hunts (revs to 2000 RPM and then back to 500 or less (stalling))
All the vacuum lines appear t be OK. Since I had bought my DPFE from Autozone I replaced it using their warranty. The EGR is holding a vacuum. THe EGR ports are clear and the throttle body ports are also clean. On a side note when I pulled off the throttle body gasket there was a lot of oil in the TB so I replaced the PCV and the line running to it.
Any ideas on what I should check next. I have not tested teh EGR solenoid, does anyone have the proceure for doing so
Thanks
Thanks
