I have a 1996 Taurus GL with 74,000 miles on it. Recently the computer has been throwing an "EGR - Insufficient Flow" code at me. I replaced the EGR valve and the light went away for one day and then came back. Now it is idling rough and feels restricted. Any thoughts where I should go next?
P0401 is due to a failed DPFE sensor 98% of the time. The other 2% would be rotted / disconnected hoses to DPFE sensor or plugged EGR passages in the intake / throttle body, or a failed EVR (EGR vacum regulator) solenoid. Ford EGR valves VERY rarely fail. Who told you to replace the EGR valve for this code?
DPFE is on the back of the intake, attached with 2 bolts. Has 3 terminal electrical connector and 2 hoses that go to the pipe between exhaust manifold and EGR valve. It is around 2" x 4" x 3/4" in size.
Yes.... on OBDII Ford cars, it is a Differential Pressure Feedback EGR sensor (DPFE). PFE (Pressure Feedback EGR) was used on some EEV IV / OBDI Fords where monitoring actual EGR flow was not required.
