Looking for some pointers here as I was struggling trying to figure out the best way to attack the ECT sensor on my 2003 Duratec 24v. I'm hoping someone on here can let me know what they had to remove in order to get to this sensor. I can see it, could probably turn it, but can't reach the locking tab on the under side.
I got to this point by getting my first CEL ever on this car in 19yrs. She's been solid to say the least. P0125 which typically is a stuck thermostat in most cases but given the age and what I saw on my ODB scan tool of coolant never quite reaching more than 125 degrees yet my dash gauge always showed normal. I decided to change out the thermostat and both sensors just in case. All Motorcraft parts.
The sensor just behind the thermostat was easy, just remove a small clip/pin and out it came.
The thermostat was a bit more troublesome but I managed to get enough clearance removing the battery, battery tray, and the air intake box.
The last item is the ECT or CHT whatever it may be called. This is on the cylinder head and goes in with a 1/4 turn and a small tab that locks it in place.
My next go at it tomorrow may be to remove the throttle body and possibly get some pliers in to remove the thermostat housing as it seems that's the main culprit blocking my access.
Any help is appreciated!
Thanks!
Thanks!
