Anybody with FFV using E85 routinely and saving money? I started using it lately, but I'm not sure it's cheaper...
I did it for a while. Price per gallon has to be at least proportional to your loss in fuel economy (25-30% loss for me) to make it worthwhile. Plus, when you switch back, it takes a while to recover the fuel economy. The car tends not to start as easily when you switch back until you get through half a tank - which means more $$$ loss.
Someone on here stated that they were mixing 87 and e85 at some proportion and getting better results. Too much chemistry for me.
If you're having a hard time starting in the dead cold of winter, the car starts easier on e85, other than that I won't use it.
You can check prices and spread trends here:
http://e85prices.com/new-york.html#
If you check the maintenence guide that came with the car - using flex-fuel more than 50% of the time puts you in a SEVERE DUTY usage category; Ford changes the recommended oil change interval from 5,000 miles to 3,000 miles. I would imagine the "severe duty" schedule would also apply to such things as the fuel filter, spark plugs etcetera.
How exactly did you get a car to start EASIER on E85 in the dead cold over regular 87? E85 is basically grain alcohol...E85 in cold temps is a NIGHTMARE!!! Also, the reason you loose fuel economy is because to properly run E85 you have to have a 20%-35% richer Air Fuel Ratio...hence less economy...just stick to regular gas...unless you plan on adding forced induction or some SERIOUS head work...DONT BOTHER WITH E85...
Wait what? Your car started just fine in the dead of winter on E85 but not well with 87 octane? I think your a little confused.
nope - in fact many times I'd reach in from the passenger side, put the key in and give it a quick flick to start it, then go about my business scraping the ice off the car while it warmed up. The only reason I have for using e85 is less strain on the starter when there's going to be a cold stretch in winter.
On 87, when it's below zero, it may take a couple tries and doesn't idle as smooth until it warms up.
