use the block, heads, front cover, oil pan, w-pump, and lower intake, from the flex engine, then mount all the non flex items to it. no harness troubles, bad grounds, etc etc that comes with a major rewire job. then you can raise the rear and steal the larger tank.
you people work too hard, work smarter.
