I'm trying to fix the red/green vacuum lines on a 99 Duratec pre-Etest, spliced them a couple months ago, but they are leaking again. Is there a part # I can replace, which includes the elbow that plugs into the UIM or are there specs (guage?) for replacement line I can purchase to replace the current. I'm assuming rubber line will not cut it due to the heat resistance requirements?
QUOTE (Gen24 @ Jun 3 2010, 08:36 AM) index.php?act=findpost&pid=808924
I'm trying to fix the red/green vacuum lines on a 99 Duratec pre-Etest, spliced them a couple months ago, but they are leaking again. Is there a part # I can replace, which includes the elbow that plugs into the UIM or are there specs (guage?) for replacement line I can purchase to replace the current. I'm assuming rubber line will not cut it due to the heat resistance requirements?[/b]
i replaced the lines with rubber ones about two years ago still running great. i left some of the colored lines at the tips and shoved the rubber line over the plastic hose and glued it in place it worked just fine. :)
