1 - 13 of 13 Posts
T
Guest
I Made this for newbies and novice 3.0L Duratec engine owners. This Shows where some things are on your Gen 4 Ford or Sable. Good Luck! Revised: Special Thanks to Jeff K. For input. Update Also includes Fuel Filter Location.
  • Like
Reactions: sheila
The thing labled "EVAP cannister" is actually the EVR (EGR Vacuum Regulator) solenoid.
T
Guest
Will redo soon. More detail and correction. Thanks all.
Very nicely done! I'm going to favorite this thread so that I can use it for reference when I need to show someone were something is.
Sent from AutoGuide.com App
Once you correct the image I can link it to the topic finder
T
Guest
Updated all. Special Thanks to Jeff K. Peace all!!
If I get a P0446 CEL, is this what it is referring to?
TIA,
Jim
P0446 Causes
  • Missing fuel cap
  • Defective Evaporative Vent Valve
  • Defective or damaged fuel cap
  • Distorted, damaged or cracked Fuel Tank Filler Neck
  • Torn or punctured Evaporative system hose(s)
  • Defective Fuel Tank Sending Unit gasket or seal
  • Split or damaged Carbon Canister
  • Defective or damaged fuel tank
  • Copy and past from internet.
  • -chart-
1 - 13 of 13 Posts
