Previous owner must have taken the DRL fuse out. When I replaced it, the headlights come on when the headlight switch it turned off and stay on even when the ignition is not in the run position. Does this sound like a DRL module problem?
I guess a lot of people don't like the DRL (interferes with covert activities), but I like them for dawn or dusk driving because they make me visible to other drivers if I forget to turn on my lights (most accidents are caused by poor visibility. I think they are required by legislation where I live in Ontario.Originally posted by Nidan@Oct 23 2004, 01:54 AM
I don't like DRL's personally .......... And you may need them to work if you ever want the car to pass a safety, depending on the laws where you live. In Canada, DRLs have to work. If you want/need them, either grab a new module from the dealer, or try your luck at a wrecker, altho i don't know if they'll take back an electrical component if it doesn't work any better than yours does. They aren't hard to change. Most are under the left front fender, behind the splash shield, dep. on the year of your bull.
