· Registered
i had driving lamps for a little while now but they were on a switch under my dash. i want to run them on a relay with the regular lights. my main issue right now is if i run them off the low beam wire, then wont they turn off with high beams? and i probably cant connect the high and low wire together at the relay. also, which wire is which on the headlight harness? i really only need to the the drivers side headlight.
· Registered
Quick fix for driving lamps-used on 5 current/past vehicles. Extra floor dimmer switch
wired to driving lamps through relay. Put it next to "dead petal" keeps hands on wheel, and no reaching or fumbling. Keep your separate circuit.
· Premium Member
Yeah, keep the driving lights on a separate switch so that you can still turn them off separate from the regular lights. And yes, you can either use a diode to wire them off one relay or you can use two relays. If it were mine, I would wire them off the high beams, no need to have driving lights on with low beam.
