2003 Taurus 3.0L EFI OHV
Drivers window works sometimes and sometimes not at all. You can press the button and hear a click sound from under the dash but the window will not move then 10 minutes later works just fine. ONLY seems to affect the drivers side window, all other windows work fine even when the drivers window will not work.
I have changed the whole switch in the drivers door but the problem still persists.
Any thoughts or ideas?
Wonder if theres a broken wire somewhere between the door and under the dash causing it to work intermittently.
I not really sure, I tried to check the wires before I got the switch module but I did not find any problems or loose connections.
