· Registered
its a pain in the rear to close the door now cause when I pull on the handle the panel just pulls away from the door. the plastic that the bolt goes through inside the handle is broken...
anyone have a quick fix... Im lookin for a new panel as i type.
Thanks
Adam
· Premium Member
Thanks
Adam
Washers and a longer screw would be a quick fix. If you take off the entire panel you can put a washer underneath and it will look cleaner than the first method I mentioned.
