If it's anything like a '95 and ASSuming you have power windows..... remove the sail panel with one phillips screw (the trim by the mirror). Remove one screw in the panel, in front of the pocket, lower front. Remove one screw from under the armrest. Pull. Rotate the lamp housing a quarter turn and the light comes out. There's two screws holding the switch assembly in. Take those out, pull, rotate and push the switch assembly back through the panel. On the driver's side you'll have the power mirror switch to deal with, and maybe a module as well.
There's 9 or so clips around the edge of the panel. Any FLAPS will have them, some sell by the piece, some in packs of 3 (most likely in the 'Help!' brand). You might get lucky and find them somewhere like Home Depot or Lowes too. They're pretty much a 'use once and replace' item, especially when they're that old. The teeth get ripped off every time they're removed. Good luck.
If you're missing the screw under the armrest, replace it. The panel clips will thank you.
