1 - 10 of 10 Posts
The panel on my drivers side door is a mess. The prongs that hold it to the door are broken and the vinyl needs to be replaced. I want to go to a junk yard and get a panel. What kind of tool do I need to remove this small panel from the door?
If you go to amazon, there's a kit with the panel removal tools as well as an assortment of panel clips. It's not expensive but will get the job done.
Thanks for the tip! My Drivers' door panel is missing a few clips, I think. I wonder if I can get the cargo net clips on Amazon, too......
I'm pretty sure I've seen similar items at harbor freight also if you have one nearby
I'm guessing the nearest Harbour Freight might be about 250 miles away. There are other parts stores closer, but I suspect Amazon might be the best bet.
1 - 10 of 10 Posts
