I've got a power window problem in my driver side door in my '00 Sable LS Premium. Don't think it'll be a problem removing the door panel but I fear the door air bag since I've never un-done a door with an air bag.
I'll disconnect the battery ground before staring..... will that assure I don't deploy the air bag?
The Side Airbags are located in the seats. Don't worry about the door panel.
G
In the event you do need to remove them though, disconnecting the battery for one minute will disable the airbags.
My haynes manual says that it takes 2 minutes to discharge and you should disconnect the negative cable first, then the positive. To hook up, first the positive, then the negative when done.
